10-11-2021
10:10 PM
- Mute
- Permalink
- Report
10-11-2021
10:10 PM
Hello everyone
I have this VBA code that check for each occurrence if it is suppressed. If yes it will unsuppress. Then it recursively calls itself if the occurrence is assembly.
Sub Main()
Dim oAsmDoc As Inventor.AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = oAsmDoc.ComponentDefinition
Dim oOccurrences As ComponentOccurrences
Set oOccurrences = oAsmCompDef.Occurrences
Zapnuti_occurrence oOccurrences, oAsmDoc
End Sub
Sub Zapnuti_occurrence(oOccurrences As ComponentOccurrences, oDoc As Inventor.AssemblyDocument)
Dim oSuppress_Occurrence As Boolean
Dim oModelState As ModelState
Dim oModelState_created As Boolean
oModelState_created = False
For Each oOccurrence In oOccurrences 'tady to změnit na list
oSuppress_Occurrence = False
If oOccurrence.Suppressed = True Then
If oModelState_created = False Then
Set oModelState = ThisApplication.ActiveDocument.ComponentDefinition.ModelStates.Add("Part2Suppressed2")
End If
oOccurrence.Unsuppress
oSuppress_Occurrence = True
End If
'do stuff...
'If oSuppress_Occurrence = True Then
' oSuppress_Occurrence = False
' oOccurrence.Suppress
'End If
If oOccurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
If InStr(oOccurrence.Definition.Document.DisplayName, new_element) = 0 Then
oDoc.Update
End If
Set oDoc = ThisApplication.Documents.Open(oOccurrence.Definition.Document.FullFileName)
Zapnuti_occurrence oOccurrence.SubOccurrences, oDoc
oDoc.Save2
oDoc.Close
End If
Next
End SubWhen trying to unsuppress occurrence of subassembly, it throws this error:
It does not matter if before trying to suppress occurrence It creates new model state or not. Please do you know how to solve this problem?
