- Mute
- Permalink
- Report
Hello everyone
I have this VBA code that check for each occurrence if it is suppressed. If yes it will unsuppress. Then it recursively calls itself if the occurrence is assembly.
Sub Main()
Dim oAsmDoc As Inventor.AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = oAsmDoc.ComponentDefinition
Dim oOccurrences As ComponentOccurrences
Set oOccurrences = oAsmCompDef.Occurrences
Zapnuti_occurrence oOccurrences, oAsmDoc
End Sub
Sub Zapnuti_occurrence(oOccurrences As ComponentOccurrences, oDoc As Inventor.AssemblyDocument)
Dim oSuppress_Occurrence As Boolean
Dim oModelState As ModelState
Dim oModelState_created As Boolean
oModelState_created = False
For Each oOccurrence In oOccurrences 'tady to změnit na list
oSuppress_Occurrence = False
If oOccurrence.Suppressed = True Then
If oModelState_created = False Then
Set oModelState = ThisApplication.ActiveDocument.ComponentDefinition.ModelStates.Add("Part2Suppressed2")
End If
oOccurrence.Unsuppress
oSuppress_Occurrence = True
End If
'do stuff...
'If oSuppress_Occurrence = True Then
' oSuppress_Occurrence = False
' oOccurrence.Suppress
'End If
If oOccurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
If InStr(oOccurrence.Definition.Document.DisplayName, new_element) = 0 Then
oDoc.Update
End If
Set oDoc = ThisApplication.Documents.Open(oOccurrence.Definition.Document.FullFileName)
Zapnuti_occurrence oOccurrence.SubOccurrences, oDoc
oDoc.Save2
oDoc.Close
End If
Next
End SubWhen trying to unsuppress occurrence of subassembly, it throws this error:
It does not matter if before trying to suppress occurrence It creates new model state or not. Please do you know how to solve this problem?
- Mute
- Permalink
- Report
It's the desired behavior and pointed out in the LOD to MS migration document (https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/important-for-developers-working-with-l...
To achieve what you want you should work in the context of oOccurrence parent document.
Or consider to make the occurrence invisible instead if it's just what you need.
- Mute
- Permalink
- Report
Sub Main()
' Dim oAsmCompDef As AssemblyComponentDefinition
' Set oAsmCompDef = oAsmDoc.ComponentDefinition
' Dim oOccurrences As ComponentOccurrences
' Set oOccurrences = oAsmCompDef.Occurrences
Zapnuti_occurrence(oAsmDoc)
End Sub
Sub Zapnuti_occurrence(oDoc As Inventor.AssemblyDocument)
oAsmCompDef = oDoc.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
' Dim oSuppress_Occurrence As Boolean
' Dim oModelState As ModelState
' Dim oModelState_created As Boolean
' oModelState_created = False
' If oModelState_created = False Then
' Set oModelState = ThisApplication.ActiveDocument.ComponentDefinition.ModelStates.Add("Part2Suppressed2")
' End If
' oSuppress_Occurrence = True
End If
'do stuff...
'End If
Dim oSubAsmCompDoc As AssemblyDocument
oSubAsmCompDoc = oOccurrence.Definition.Document
' If InStr(oOccurrence.Definition.Document.DisplayName, new_element) = 0 Then
' oDoc.Update
' End If
' oDoc = ThisApplication.Documents.Open(oOccurrence.Definition.Document.FullFileName)
Call Zapnuti_occurrence(oSubAsmCompDoc)
' oDoc.Save2
' oDoc.Close
End If
Next
End SubWhich inventor version are you use?
In the 2021,there is no modelstate .
Try this
- Mute
- Permalink
- Report
Thank you for your advice, could you be more specific what do you meant? Maybe post example of code?
I have modified the code that it is unsuppressing suboccurrences but this does not work (it throws error).
Heres the code:
Sub Main()
Zapnuti_occurrence oAsmDoc
End Sub
Set oAsmCompDef = oDoc.ComponentDefinition
Dim oSubOccurrence As ComponentOccurrence
' End If
End If
'do stuff...
'End If
Set oSubAsmCompDoc = oOccurrence.Definition.Document
' oDoc.Update
' End If
For Each oSubOccurrence In oOccurrence.SubOccurrences
If oSubOccurrence.Suppressed = True Then
' End If
oSubOccurrence.Unsuppress
End If
Next
' oDoc.Save2
' oDoc.Close
End If
Next
End Sub
- Mute
- Permalink
- Report
Sorry I work with Inventor 2022, so there are model states and the behaviour of occurrences and suboccurrences is different..
- Mute
- Permalink
- Report
What if you change this:
To this:
Zapnuti_occurrence oDoc.ComponentDefinition.Occurrences, oDoc
- Mute
- Permalink
- Report
Thank you, it works!
Here is the final code:
Sub Main()
End Sub
End If
'do stuff...
'End If
oDoc.Update
End If
oDoc.Save2
oDoc.Close
End If
Next
End Sub
- Mute
- Permalink
- Report
Sub Main()
End Sub
Sub Zapnuti_occurrence( oDoc As Inventor.AssemblyDocument)
oOccurrences =oDoc.ComponentDefinition.Occurrences
End If
oDoc.Update
End If
Rem In the Opened Asm File,All the oOccurrence were opened in memeroy,needn't use the document open method again; try this.
Zapnuti_occurrence oOccurrence.Definition.Document
End If
Next
oDoc.Save
End SubIn the Opened Asm File,All the oOccurrence were opened in memeroy,needn't use the document open method again; try this.
