10-11-2021
12:19 PM
- Mute
- Permalink
- Report
10-11-2021
12:19 PM
This will work:
Public Sub Main()
Dim oApp As Inventor.Application
Set oApp = GetObject(, "Inventor.Application") 'Set reference to the running instance of Inventor
Call InventorScreen(oApp, False, False, True) ' Minimize Inventor and disable screen updates
End Sub
Public Sub InventorScreen(ByRef oApp As Inventor.Application, Visible As Boolean, ScreenUpdating As Boolean, Minimized As Boolean)
If Visible = True Then
oApp.Visible = True
ElseIf Visible = False Then
oApp.Visible = False
End If
If ScreenUpdating = True Then
oApp.ScreenUpdating = True
'oApp.ActiveView.Update
ElseIf ScreenUpdating = False Then
oApp.ScreenUpdating = False
End If
If Minimized = True Then
oApp.WindowState = kMinimize
ElseIf Minimized = False Then
oApp.WindowState = kMaximize
End If
End Sub
Arthur Knoors
Autodesk Affiliations:
