@bradeneuropeArthur ,
Thanks for all the help. I have one last oddball that occurs now since the update to INV2022.1.1. I have the following snippets of code that I use to keep INV minimized while capturing thumbnails of multiple parts to prevent the cursor from highlighting faces. The screen still minimizes just fine, but then it pops up again on a file open. This did not happen in INV2022 prior to the update. Any thoughts?
Public oApp As Inventor.Application
Set oApp = GetObject(, "Inventor.Application") 'Set reference to the running instance of Inventor
Call InventorScreen(oApp, False, False, True) ' Minimize Inventor and disable screen updates
Public Sub InventorScreen(ByRef oApp As Inventor.Application, Visible As Boolean, ScreenUpdating As Boolean, Minimized As Boolean)
If Visible = True Then
    oApp.Visible = True
ElseIf Visible = False Then
    oApp.Visible = False
End If
If ScreenUpdating = True Then
    oApp.ScreenUpdating = True
    'oApp.ActiveView.Update
ElseIf ScreenUpdating = False Then
    oApp.ScreenUpdating = False
End If
If Minimized = True Then
    oApp.WindowState = kMinimize
ElseIf Minimized = False Then
    oApp.WindowState = kMaximize
End If
End Sub
Many thanks.
Rafael
