10-11-2021
09:32 AM
- Mute
- Permalink
- Report
10-11-2021
09:32 AM
I actually got this same error again. In my implementation, I deactivate first, then active at the end. Here is my code. It is basically showing a userform that allows the user to pick the macro they want to run. Only certain macros need the vault add-in unloaded.
Sub UniversalNew()
strSoftwareName = "Abtex Inventor Suite " & strVersion
Dim boolUnloadVault As Boolean
boolUnloadVault = True
iActiveScreen = 0
CurrentEnvironmentNew = ActiveEnvironmentNew
SelectedProgramNew = vbNullString
UniversalFormComplete = False
UniversalFormCancelled = False
UserForm_Universal.Label_Message.Caption = vbNullString
UserForm_BillOfMaterial.Label_Message.Caption = vbNullString
UserForm_OtherMacros.Label_Message.Caption = vbNullString
UserForm_Universal.Caption = strSoftwareName
UserForm_BillOfMaterial.Caption = strSoftwareName & " - Bill of Material"
UserForm_OtherMacros.Caption = strSoftwareName & " - Other macros"
'Run Userform to collect information
UserForm_Universal.Show
Do Until UniversalFormComplete = True
DoEvents
Loop
If UniversalFormCancelled = True Then
'MsgBox "User Cancelled. Click Okay to terminate."
End
End If
Dim aai As ApplicationAddIn
Set aai = ThisApplication.ApplicationAddIns.ItemById("{48B682BC-42E6-4953-84C5-3D253B52E77B}")
Select Case SelectedProgramNew
Case "BOM"
If boolUnloadVault = True Then aai.Deactivate 'ThisApplication.ApplicationAddIns.ItemById("{48B682BC-42E6-4953-84C5-3D253B52E77B}").Deactivate
Call ExportBOM.ExportBOM
Case "Format BOM"
Call FormatBOM.FormatBOM
Case "Generate Thumbnails"
Call GenerateThumbnails.GenerateThumbnails
Case "Generate Brush"
Call MakeBrush_Tufted.TuftedBrush
Case "Create GPN"
Call FillProperties.CreateGPN
Case "Finish"
Call MakeFinish.MakeFinish
Case "Toggle Part Number"
Call ToggleColumnVisibility.TogglePartNumber
Case "Determine Parents"
Call FillProperties.DetermineParents
Case "Rename Occurences"
Call RenameOccurences.RenameOccurences
Case "Export Drawings"
Call ExportDrawings.Main
Case "Merge BOMs"
Call MergeBOMs.MergeBOMs
Case "Merge PDFs"
Call OpenPDFSAM.OpenPDFSAM
Case "Copy Sheet"
Call CopySheet.IDW_DuplicateSheet
Case "Add Part Number"
Call AddPartNumber.AddPartNumber
Case "Add Layer PN"
Call AddPartNumber.AddLayerPN
Case "Import Fastener"
Call ImportFastener.ImportFastener
Case "Delete Custom Properties"
Call DeleteCustomProperties.DeleteCustomProperties
Case "Adjust View"
Call AdjustView.CallUserForm
Case "Check Param and Rule"
Call AddPartNumber.CheckParamAndRule
Case Else
MsgBox "An error has occured."
End Select
'Reactivate Vault is failing
If boolUnloadVault = True Then aai.Activate 'ThisApplication.ApplicationAddIns.ItemById("{48B682BC-42E6-4953-84C5-3D253B52E77B}").Activate
Set aai = Nothing
'MsgBox "Ending program"
End
End Sub
Any idea what might be happening? Any help would be appreciated.
Thank you.
Rafael
