Would this help:
Sub VaultAddIn()
    Dim strResponse As String
    strResponse = MsgBox("Yes=Load, No=Unload, Cancel=Do Nothing", vbYesNoCancel, "Do you want to load/unload Vault Add In?")
    Dim aai As ApplicationAddIn =ThisApplication.ApplicationAddIns.ItemById("{48B682BC-42E6-4953-84C5-3D253B52E77B}")
    Select Case strResponse
        Case vbYes
            aai.Activate
        Case vbNo
            aai.Deactivate
			aai= Nothing
    End Select
End Sub
Arthur Knoors
Autodesk Affiliations:
