10-09-2021
01:29 AM
- Mute
- Permalink
- Report
10-09-2021
01:29 AM
Hello
I've cleaned your code a bit. As I understand, you want to export every visible part in your assembly to an single STEP file. No export of the entire assembly or any subassemblies. Is this correct?
Try this one:
Option Explicit On
Sub Main()
'check that the active document is an assembly file
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
End If
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
Dim sAsmName As String = System.IO.Path.GetFileNameWithoutExtension(oAsmDoc.FullDocumentName )
Dim sFolder As String = "C:\Users\STEFANIA\Desktop\Nuova cartella (3)" & "\" & sAsmName & " STEP Files"
Dim STEPTranslator As TranslatorAddIn
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
Call ConfigureSTEPTranslatorSettings(STEPTranslator, oContext, oOptions, oDataMedium)
If Not System.IO.Directory.Exists(sFolder) Then
System.IO.Directory.CreateDirectory(sFolder)
End If
'look at the files referenced by the assembly
Dim oRefDoc As Document
For Each oRefDoc In oAsmDoc.AllReferencedDocuments
If Not oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Continue For
'get all occurrences of the referenced file, if one on them is visible - export that file to STEP, otherwise skip
Dim oOccs As ComponentOccurrencesEnumerator = oAsmDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefDoc)
Dim oOcc As ComponentOccurrence
Dim bVis As Boolean = False
For Each oOcc In oOccs
If oOcc.Visible
bVis = True
Exit For
End If
Next
If bVis = False Then
Continue For 'Next For
End If
'check that model is saved
If(System.IO.File.Exists(oRefDoc.FullDocumentName)) Then
Dim sFilename As String = System.IO.Path.GetFileNameWithoutExtension(oRefDoc.FullDocumentName)
Dim sDesc As String = oRefDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
Parameter.Quiet = True
Dim sSospensione As String = Parameter("sospensione")
oDataMedium.FileName = sFolder & "\" & sFilename & "_" & sSospensione & sDesc & ".stp"
Try
Call STEPTranslator.SaveCopyAs(oRefDoc, oContext, oOptions, oDataMedium)
Catch
MsgBox("Export of " & oRefDoc.DisplayName & " failed. Continue next one", MsgBoxStyle.Critical)
End Try
End If
Next
MessageBox.Show("New Files Created in: " & vbLf & sFolder, "iLogic")
Shell("explorer.exe " & sFolder,vbNormalFocus)
End Sub
Sub ConfigureSTEPTranslatorSettings(ByRef oSTEPTranslator As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
' Set application protocol.
' 2 = AP 203 - Configuration Controlled Design
' 3 = AP 214 - Automotive Design
oOptions.Value("ApplicationProtocolType") = 3
' Other options...
'oOptions.Value("Author") = ""
'oOptions.Value("Authorization") = ""
'oOptions.Value("Description") = ""
'oOptions.Value("Organization") = ""
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'oDataMedium.FileName = ThisDoc.PathAndFileName(False) & ".stp"
End If
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
