j.haggenjos
in reply to: j.haggenjos
Thank you @WCrihfield  for the input.
At the time, my workflow was to have a main rule run and call different rules depending on the situations. Shared Variable was my way of having a common dataset.
You are right, I probably could have improved by structuring the code differently and referencing other rules as classes and use the underlying functions instead of simply calling the rules when I needed the code in them.
However, as the complexity of my tool grew, I decided to take the time and move it to an AddIn.
