- Mute
- Permalink
- Report
Thanks for your reply. I tried that code provided by Rob67ert and it works almost perfectly.
Now I found that there's a property added to the part where it defines a custom property as "PF_PRT_ZNR" and if that's missing it adds an 'XXX' in front of the part number. I'll figure that out and delete when I have the time to inspect.
Other thing is, while examining the code it came to my mind that why don't I make those parts (Dibond, Vivak etc) sheet metal also? They will be exported too and the part type doesn't matter in the assembly. So all in all I changed my design routine a bit, created Sheet metal defaults for polycarbonate and dibond (bit funny but it works).
My only problem left is the export folder. I want to export the DXFs to the same folder I export my STEP and PDF files with DrawingPorter. I post a screenshot of my folder path.
I'll be grateful if someone could help me in that.
Thanks in advance.
Cheers,
Balázs
