WCrihfield
in reply to: JamesMeBoi
Yes.  That part is much simpler.  The ComponentOccurrence object has a Property called "Grounded" that is Read/Write and has a Boolean type value.  So a line like this should do the trick:
If Not oSubAsmOcc.Grounded Then
	oSubAsmOcc.Grounded = True
End If
or
Component.InventorComponent("SubAsmName:1").Grounded = True
Wesley Crihfield
(Not an Autodesk Employee)
