A.Acheson
in reply to: rprivittB3TTG
150 would be easier to find with or without ilogic and fix than working with a wrongly functioning part. You could simply make a rule to identify that part number or family  in a folder of files and replace that type of part with your new part.  I have used the extrude cut method for a walkway grip channel I wanted to look realistic but the pattern took too long to process by changing the length so it was a time saver to extrude cut to a shorter length.
Regards
Alan
