WCrihfield
in reply to: rprivittB3TTG
It sounds to me like you may need to dig into the actual MassProperties object of your 'model' documents, instead of just trying to pull from the iProperties.  The MassProperties object can be found under the PartComponentDefinition and the AssemblyComponentDefinition.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) :thumbs_up:.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :light_bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
