aabiskar.basyal
283 Views, 1 Reply
Creating iassembly for more than 200 types of gas struts with parameter from an excel file in fast and efficient way.
I want to thank everyone in this community for your brilliant post and kind suggestions. It has helped me heaps.
I am trying to create iassembly of gas struts. I have an excel file with more than 200 types of gas struts with different part numbers, extended length, forces, diameter of piston and cylinder. I could quickly create ipart Piston file by pasting parameter from my excel file directly to the excel file generated by ipart Piston file. And derive the dimension for Cylinder Part file by linking it to parameters of ipart piston file.
However this way everytime I place the gas struts assembly I need to change the piston ipart file configuration and save the assembly with different name. I want to make the gas struts assembly as iassembly so it stays clean and easy.
However, to create an gas struts iassembly I need to create more than 200 rows individually inside the iassembly author and choose the different ipart member of the piston ipart for every iassembly member configuration. Is there a efficient way and fast way of doing it with some other techniques, ilogic or with other script?
Thank you so much really appreciate your help.
