emanuel.c
in reply to: emanuel.c
Yes, thanks Chris. I noticed that later and corrected it, then it worked great. I also added a Try - Catch in there because I needed it to try to create a flat pattern in case a sheet metal body was built but flat pattern wasn't made yet.
Dim opart As PartDocument = ThisDoc.Document
Dim smCompDef As SheetMetalComponentDefinition = opart.ComponentDefinition
Dim smlength As Double
Dim smwidth As Double
Dim oSMthk As Double = Parameter("Thickness")
If smCompDef.HasFlatPattern Then
	smlength = (smCompDef.FlatPattern.Length + oSMthk) / 2.54
	smwidth = (smCompDef.FlatPattern.Width + oSMthk) / 2.54
	Else
	Try
		smCompDef.Unfold()
	Catch
	End Try
	End If
	Dim AreaPronest As Double = smlength * smwidth / 144
	If Parameter("Thickness") >= 0.1875 Then
		getstock ="Plate, " & Format(oSMthk, "0.000") & " thk x " & Format(AreaPronest, "0.00") & " ft^2"
	Else
		getstock ="Sheet Metal, " & Format(oSMthk, "0.000") & " thk x " & Format(AreaPronest, "0.00") & " ft^2"
	End If
