09-21-2021
07:07 PM
- Mute
- Permalink
- Report
09-21-2021
07:07 PM
The only error I could bring up is when no model was present in one of the sheets. As this rule loops through all sheets and looks for view (1) if missing it will error out. Included in the rule below is an error trap for skipping the sheet renaming when no view is present. If this still doesn't work can you post the error message that you have received?
Sub Main() 'Purpose: Push file name to sheet name '21-Sept-16 Dim oDoc As Document = ThisApplication.ActiveDocument Dim oSheet As Sheet Dim oDrawingView As DrawingView 'Iterate through sheets For Each oSheet In oDoc.Sheets Try 'Grab the first drawing view on the sheet oDrawingView = oSheet.DrawingViews(1) 'Grab the model of the first drawing view oModel = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument 'Assign the sheet name based off of the file name, with the path and extension removed oSheet.Name = System.IO.Path.GetFileNameWithoutExtension(oModel.FullFileName) Catch 'Error no view so skip End Try Next End Sub
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
