emanuel.c
in reply to: Michael.Navara
Thank you Michael, I didn't know it had the API.
I still get errors, only when there isn't a flat pattern available and can't figure it out... Unspecified Error (Exception from HRESULT: 0x80004005 (E_FAIL)).
' Code to write "Stock Size" iProperty
Sub Main()
Dim invdoc As Document
invdoc = ThisDoc.Document
'Function GetUserParams returns UserParameters Collection
oUserParams = GetUserParams(invdoc)
'Function FindParameter returns the looked for parameter
paraFL = FindParameter(invdoc, "FL")
If paraFL IsNot Nothing Then
	'MessageBox.Show("Parameter does exist", "Title")
Else
	'MessageBox.Show("Parameter does not exist", "Title")
	paraFL = oUserParams.AddByValue("FL", 0, UnitsTypeEnum.kInchLengthUnits)
End If
Dim oPart As PartDocument = ThisDoc.Document
	Dim oSS As String = StockSize(oPart)
	Logger.Info(oSS)
End Sub
'See if parameter FL exists
Public Function FindParameter(invdoc As Inventor.Document, strParameter As String) As Parameter
Dim cd As ComponentDefinition = Nothing
Select Case invdoc.DocumentType
    Case Is = Inventor.DocumentTypeEnum.kAssemblyDocumentObject
		'MessageBox.Show("Is a Assembly", "Title")
        Dim docAssembly As Inventor.AssemblyDocument = invdoc
        cd = docAssembly.ComponentDefinition
    Case Is = Inventor.DocumentTypeEnum.kPartDocumentObject
		'MessageBox.Show("Is a Part", "Title")
        Dim docPart As Inventor.PartDocument = invdoc
        cd = docPart.ComponentDefinition
End Select
If cd IsNot Nothing Then
    For Each param As Inventor.Parameter In cd.Parameters
        If param.Name = strParameter Then
            Return param
		End If
    Next
End If
 Return Nothing
End Function
'Get user parameters collection
Public Function GetUserParams(invdoc As Inventor.Document) As UserParameters
    End Select
Dim oParams As Parameters oParams = cd.Parameters Dim oUserParams As UserParameters oUserParams = oParams.UserParameters Return oUserParams End If Return Nothing End Function
Private Function StockSize(part As PartDocument) As String Dim oStock As String = getstock(part) Dim propertyName As String = "STOCK SIZE" Dim PropertyValue As String = oStock Dim oCProps As PropertySet = part.PropertySets.Item("Inventor User Defined Properties") Dim oSSProp As Inventor.Property Dim oExists As Boolean = False For Each oCProp As Inventor.Property In oCProps If oCProp.Name = propertyName Then oSSProp = oCProp oSSProp.Value = PropertyValue oExists = True End If Next If oExists = False Then oSSProp = oCProps.Add(propertyName, propertyName) End If StockSize = oSSProp.Value End Function 'Write stock size for each part shape Private Function getstock(part As PartDocument) As String Dim oFL As Double = Parameter("FL") Select Case iProperties.Value("Inventor User Defined Properties", "Product") Case "01 Sheet Metal" Dim opart As PartDocument = ThisDoc.Document Dim smCompDef As SheetMetalComponentDefinition = opart.ComponentDefinition Dim smlength As Double = SheetMetal.FlatExtentsLength 'sheet metal flat pattern length Dim smwidth As Double = SheetMetal.FlatExtentsWidth 'sheet metal flat pattern width Dim AreaPronest As Double = (smlength + Parameter("Thickness")) * (smwidth + Parameter("Thickness")) / 144 Dim oSMthk As Double = Parameter("Thickness") If smCompDef.HasFlatPattern Then If Parameter("Thickness") >= 0.1875 Then getstock ="Plate, " & Format(oSMthk, "0.000") & " thk x " & Format(AreaPronest, "0.00") & " ft^2" Else getstock ="Sheet Metal, " & Format(oSMthk, "0.000") & " thk x " & Format(AreaPronest, "0.00") & " ft^2" End If End If Case "02 Pipe" Dim oPipeD As Double = Parameter("G_D_Nom") oL = FormatAsFraction(oPipeD) getstock = "Pipe, " & oL & " sch." & Parameter("Schedule") & " x " & Format(oFL, "0.00")
End Select
End Function
