emanuel.c
in reply to: WCrihfield
Hmm, I forgot about the Try Catch, thank you. However I still get an error: Conversion from string "iLogic" to type "Integer" is not valid. Here is the code if there's something else related to it, though I suspected it was because there was no metal to flat bend yet, since it works OK otherwise. I guess if I'd be using VB I could run it line by line to see where the issue is... I'm still working on the code and it's kind of pieced together as best I knew how.
Basically it detects if parameter "FL" exists (which is not needed for flat metal shapes, so it shouldn't be created for sheet metal parts - still need to work on that) then if iProperty "Stock Size" exists it populates that according to iProperty "Product".
Thank you for helping out!
' Code to write "Stock Size" iProperty
Sub Main()
Dim invdoc As Document
invdoc = ThisDoc.Document
'Function GetUserParams returns UserParameters Collection
oUserParams = GetUserParams(invdoc)
'Function FindParameter returns the looked for parameter
paraFL = FindParameter(invdoc, "FL")
If paraFL IsNot Nothing Then
	'MessageBox.Show("Parameter does exist", "Title")
Else
	'MessageBox.Show("Parameter does not exist", "Title")
	paraFL = oUserParams.AddByValue("FL", 0, UnitsTypeEnum.kInchLengthUnits)
End If
Dim oPart As PartDocument = ThisDoc.Document
	Dim oSS As String = StockSize(oPart)
	Logger.Info(oSS)
End Sub
'See if parameter FL exists
Public Function FindParameter(invdoc As Inventor.Document, strParameter As String) As Parameter
Dim cd As ComponentDefinition = Nothing
Select Case invdoc.DocumentType
    Case Is = Inventor.DocumentTypeEnum.kAssemblyDocumentObject
		'MessageBox.Show("Is a Assembly", "Title")
        Dim docAssembly As Inventor.AssemblyDocument = invdoc
        cd = docAssembly.ComponentDefinition
    Case Is = Inventor.DocumentTypeEnum.kPartDocumentObject
		'MessageBox.Show("Is a Part", "Title")
        Dim docPart As Inventor.PartDocument = invdoc
        cd = docPart.ComponentDefinition
End Select
If cd IsNot Nothing Then
    For Each param As Inventor.Parameter In cd.Parameters
        If param.Name = strParameter Then
            Return param
		End If
    Next
End If
 Return Nothing
End Function
'Get user parameters collection
Public Function GetUserParams(invdoc As Inventor.Document) As UserParameters
    End Select
			Dim oParams As Parameters
			oParams = cd.Parameters
			Dim oUserParams As UserParameters
			oUserParams = oParams.UserParameters
             Return oUserParams
    End If
	 Return Nothing
End Function
Private Function StockSize(part As PartDocument) As String
	Dim oStock As String = getstock(part)
	Dim propertyName As String = "STOCK SIZE"
	Dim PropertyValue As String = oStock
	Dim oCProps As PropertySet = part.PropertySets.Item("Inventor User Defined Properties")
	Dim oSSProp As Inventor.Property
	Dim oExists As Boolean = False
	For Each oCProp As Inventor.Property In oCProps
		If oCProp.Name = propertyName Then
			oSSProp = oCProp
			oSSProp.Value = PropertyValue
			oExists = True
		End If
	Next
	If oExists = False Then
		oSSProp = oCProps.Add(propertyName, propertyName)
	End If
	StockSize = oSSProp.Value
End Function
'Write stock size for each part shape
Private Function getstock(part As PartDocument) As String
Dim oFL As Double = Parameter("FL")
Select Case iProperties.Value("Inventor User Defined Properties", "Product")
	Case "01 Sheet Metal"
		Try
			Dim smlength As Double = SheetMetal.FlatExtentsLength 'sheet metal flat pattern length
			Dim smwidth as Double = SheetMetal.FlatExtentsWidth 'sheet metal flat pattern width
			Dim AreaPronest As Double = (smlength + Parameter("Thickness")) * (smwidth + Parameter("Thickness")) / 144
			Dim oSMthk As Double = Parameter("Thickness")
			If Parameter("Thickness") >= 0.1875 Then
				getstock ="Plate, " & Format(oSMthk, "0.000") & " thk x " & Format(AreaPronest, "0.00") & " ft^2"
			Else
				getstock ="Sheet Metal, " & Format(oSMthk, "0.000") & " thk x " & Format(AreaPronest, "0.00") & " ft^2"
			End If
		Catch oEx As Exception
			MsgBox("Failed to get SheetMetal.FlatExtents size.", "iLogic")
		End Try
	Case "02 Pipe"
		Dim oPipeD As Double = Parameter("G_D_Nom")
		oL = FormatAsFraction(oPipeD)
		getstock = "Pipe, " & oL & " sch." & Parameter("Schedule") & " x " & Format(oFL, "0.00")
	Case "03 Angle"
		Dim Athk As Double = Parameter("G_T")
		Dim AH As Double = Parameter("G_H")
		Dim AW As Double = Parameter("G_W")
		getstock = "L " & Format(AW, "0.00") & " x " & Format(AH, "0.00") & " x " & Format(Athk, "0.00") & " x " & Format(oFL, "0.00")
	Case Else
		getstock = "not defined"
	End Select
End Function
