1)  If you have more than one parts list on the sheet, are you sure they all have different titles?  If not, later ones with same name one would likely overwrite earlier ones with that name, because if their titles are the same, then their 'TableName' in the export will also be the same.
2)  If there is more than one 'loom run' on the sheet, later ones would overwrite earlier ones for the same reason.  Since the name isn't being incremented, the 'TableName' would be the same for each.
Other than that, I'm not sure why it would be acting differently now then it was then, unless Autodesk changed something on their end about the way that 'Export' method works.
Wesley Crihfield
(Not an Autodesk Employee)
