Hi @Zachary.BeasonD97A7.  Just curious about one thing that I'm seeing right now that doesn't look right to me.  As I am reading down through your posted code from top to bottom, I see the where the String type variable "lname" is created, but then I don't see where you have assigned it a value before you are setting this variable as the Value of the Option called "TableName" the first time (when looping through PartsLists).  Is that a mistake?  I see that you have given this variable a value before using it this way in the two other two loops below (for wire runs, cable runs, & loom runs).
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) :thumbs_up:.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :light_bulb:or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
