09-16-2021
10:39 AM
- Mute
- Permalink
- Report
09-16-2021
10:39 AM
I have a macro that exports several tables to excel for our harness drawings. With Inventor 2020 everything worked fine and each list I exported went to its own sheet in Excel. Since we updated to 2022 it's not making a new tab for each table exported. I have no idea what I need to change to get all my tables on different worksheets. Any help is appreciated.
Private Sub ExcelOut(name As String)
Dim odoc As Document
Set odoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = odoc.Sheets(1)
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oOptions.Value("IncludeTitle") = True
oOptions.Value("AutoFitColumnWidth") = True
Dim oPartsList As PartsList
Dim i As Integer
i = 1
Dim lname As String
Dim excelname As DataMedium
Set excelname = ThisApplication.TransientObjects.CreateDataMedium
excelname.filename = name & ".xlsx"
Dim fName As String
fName = excelname.filename
If Dir(fName) <> "" Then
MsgBox "Excel sheet alreaedy exists. Excel will not be exported."
Exit Sub
End If
' export Parts Lists to excel
For Each oPartsList In oSheet.PartsLists
Set oPartsList = oSheet.PartsLists(i)
oOptions.Value("TableName") = lname
MsgBox (oOptions.Value("TableName"))
oPartsList.Export fName, kMicrosoftExcel, oOptions
i = i + 1
Next
'export Wire Run Lists to excel
lname = ""
Dim oWireRun As CustomTable
Dim j As Integer
j = 1
i = 1
For Each oWireRun In oSheet.CustomTables
If oWireRun.Title = "WIRE RUN LIST" Then
Set oWireRun = oSheet.CustomTables(i)
lname = "WIRE RUN LIST " & j
oWireRun.Export fName, kMicrosoftExcelFormat, oOptions
j = j + 1
End If
i = i + 1
Next
'export Cable Run Lists to excel
lname = ""
Dim oCableRun As CustomTable
j = 1
i = 1
For Each oCableRun In oSheet.CustomTables
If oCableRun.Title = "CABLE RUN LIST" Then
Set oCableRun = oSheet.CustomTables(i)
lname = "CABLE WIRE RUN LIST " & j
oCableRun.Export fName, kMicrosoftExcelFormat, oOptions
j = j + 1
End If
i = i + 1
Next
'export Wire Loom Lists Lists to excel
lname = ""
Dim oLoomRun As CustomTable
i = 1
For Each oLoomRun In oSheet.CustomTables
If oLoomRun.Title = "LOOM PARTS LIST" Then
Set oLoomRun = oSheet.CustomTables(i)
lname = "LOOM PARTS LIST"
oLoomRun.Export fName, kMicrosoftExcelFormat, oOptions
End If
i = i + 1
Next
End Sub
