Thanks Krieg!
My model can be either part or assembly - if this is the case would there need to be 2 conditions for this?
A significant part of the time the drawing only references 1 model
I agree with you the 'for each Sheet' is likely overkill, I played around for a few minutes and couldn't find a way to to open the document from the drawing, so it's what I found on the forum.  I'm all ears if you know a more direct way to open the referenced model
I'll play with this in a little bit and let you know how it goes, thanks for the help!
