JohnBeach
I have found another way to change multiple idw properties at once like custom properties, date, engineering approved by etc.
Select all relevant idw files in windows explorer.
Right click and select Iproperties.
Change appropriate properties and the change will appear when you open the idw in Inventor.
You may have to edit the revision box slightly to make that change appear like the date. So for that you can you just put an extra letter in the revision description or similar and then just remove that using the iproperties from within Inventor.
John
