jpi656UL
I have the same issue - the reason I also would like to have the possibility to change the custom border parameters ,especially the ZONES is that for custom border I can add anchoring points, some descriptions, symbols etc. with the proper position regardless of the sheet size (for example always 10mm from the left edge). Once the custom zone border is defined by me I manually have to always change it before placing as to suit my sheet sizes (I prefer less zones for A4, more for A0). I would like to have the border adjusted each time I change the sheet and now every sheet change I need to remove the border and place it with proper zones, otherwise they always stay the same (the last inputted values are remembered). With default border the situation is different - once placed the zones adjust automatically to paper size.
