08-26-2021
07:15 AM
- Mute
- Permalink
- Report
08-26-2021
07:15 AM
Have you read through this other post yet? It is dealing with a very similar task, but using the radio groups instead of the drop-down lists. It looks like your iLogic Form is a 'local' one, so it should be able to instantly react to parameter selections, as long as you have the iLogic rules set-up do handle the parameter value change events. Which version of Inventor are you using (year)? Are all the filter type changes happening OK for you when you make selections? If so, then are you simply trying to change the layout, and not the functionality?
Wesley Crihfield
(Not an Autodesk Employee)
