A.Acheson
in reply to: bshahiwork
It sounds like you want display data in a table in the drawing is that correct? You are right that it isn’t easy to get data in and out of a table easily.  You will need ilogic rules to inject in the contents of parameters or iproperties into the cells. So if the rows and columns constantly change in qty this could be challenging.
Have you a picture of your current layout, your data set and a list of where the data is coming from. Another option is to use excel table driven by ilogic  to display the data as an object in the drawing. Down side is the data needs to go to excel and back to the drawing and might be a bit cumbersome. So it could depend on where you have already the data stored currently and where it is coming from. Are you using cable and harness addin by any chance?
Regards
Alan
