08-21-2021
06:20 AM
- Mute
- Permalink
- Report
08-21-2021
06:20 AM
I think the best way to do this is by adding 2 dummy parameters. (InnerDiameter and WallThickness) A dummy parameter for InnerDiameter is maybe not what you expect. But you need it to see if the InnerDiameter or the WallThickness has been changed. As an example, I used a tube. In the screencast below you will see all parameters that i used.
And this is the iLogic code to make it work:
Dim wt As Double = WallThickness Dim id As Double = InnerDiameter Dim idr As Double = Parameter("InnerDiameterReal") Dim odr As Double = Parameter("OuterDiameterReal") If (DoubleUtil.DoublesAreEqual(id, idr)) Then ' wall thickness has been changed Parameter("InnerDiameterReal") = odr - 2 * wt Parameter("InnerDiameter") = odr - 2*wt Parameter("WallThickness") = wt Else ' inner diameter has been changed Parameter("WallThickness") = (odr - id)/2 Parameter("InnerDiameterReal") = id End If
Jelte de Jong
Blog: hjalte.nl - github.com
