SpokenEarth
in reply to: WCrihfield
Thank you for the time you took to review my posts and your effort to find a solution.
My thought was to have a foul constraint sketch, double dimensioning the parameter ID and make additional parameter (Wall_Thickness) with the intention to choose controlling the actual wall thickness from the parameter ID or Wall_Thickness.
I was thinking if this would possible to achieve this without making true false statement, I'm not quite sure if it will be doable by creating a List(Of String) and add ranges, I haven't  tried  yet but I don't think this would work either.
Best Regards.
Achilles
