- Mute
- Permalink
- Report
I'm not 100% sure I understand what you are wanting. Are you planning on using a Form to allow the user to specify parameter values? After looking at your model sketch and parameters, I'm guessing you want to change which 2 (out of 3) dimensions have 'driving' control, and which 1 will be 'driven'? If this is the case, you will need to access the sketch, enter into 'edit mode', find & identify those 3 dimensional constraints, then toggle their properties between 'driving' and 'driven' as needed, all though an iLogic rule. This is possible, but might be challenging/complicated to achieve. And if anything happens to those sketch dimensions (like deleted), it will leave your rule useless. Does that sound like the process you were looking for?
Wesley Crihfield
(Not an Autodesk Employee)
