helouise
in reply to: WCrihfield
What I meant is if I open the file it runs the rule and then it requires a save. Even if the properties were correct the rule still changed it so then it will prompt for save if I want to close the file.
If there are many parts in assembly this then takes a lot of time when i press save.
So I Just want the Rule to change the values if they are not correct otherwise do nothing.
It needs to check if part number is in capitals and the stock number is indeed the correct one according to Part Number if it is the do nothing.
Could you please Elaborate on your post for checking if it is dirty, I dont completely understand.
Apologies I am new to iLogic and this is a trial and Error process which takes a lot of time.
Thank you
