WCrihfield
in reply to: sundaram1087
When you say the "API Code Works fine", are you referring to one of the API Sample VBA codes(link1 , link2) (which are both the same)? If your code is not exactly like that sample, then could you maybe attach a text file of the code you are currently using, or post the code here, so we can better understand what may be needed to improve performance (if possible)?  Do your drawings usually have multiple sheets?  If so, I assume you are trying to export each sheet as a separate DXF file, right?
Wesley Crihfield
(Not an Autodesk Employee)
