@SometimesInventorMakesMeAngry wrote:
Since the .ipj settings override Application Options, maybe you can create a new folder "C:\Test Forms" where you create temporary copies of existing forms in "\Design Data" (where the production forms are). Once you're done, you can overwrite Design Data forms with Test Forms forms.
What I have done in the past, is just to setup my own "development.ipj" that uses a local Design Data location, then when things are ready to push out to production, the forms (and rules) were copied to a the shared network location.
I hope this helps.
Curtis
