08-09-2021
12:00 PM
- Mute
- Permalink
- Report
08-09-2021
12:00 PM
Hi @paulo.correia98ZAP. This is basically performing the same actions as @bradeneuropeArthur 's code, but lets you choose a directory/folder to process, instead of selecting multiple specific files. It will then process all Part documents in that folder. There is also a simple setting near the end of the oFiles() definition line, where you can change this from just processing the top/main directory, to then process all sub-folders if you wanted, but it is currently set to only process the top selected directory. It uses a regular 'Open File' dialog, that is set up to only select a folder (glorified folder selection dialog.)
Sub Main
Dim oTargetFolder As String = ChooseFolder
Dim oFileNames As New List(Of String)
Dim oFilter As String = "*.ipt"
Dim oFiles() As String = System.IO.Directory.GetFiles(oTargetFolder, oFilter, IO.SearchOption.TopDirectoryOnly)
oFileNames.AddRange(oFiles)
If oFileNames.Count = 0 Then
MsgBox("No files match the search criteria in the selected folder. Exiting.", , "")
Exit Sub
End If
For Each oFile As String In oFiles
Dim oPDoc As PartDocument = ThisApplication.Documents.Open(oFile, False)
If oPDoc.ComponentDefinition.IsiPartMember Then
oPDoc.ComponentDefinition.iPartMember.BreakLinkToFactory
oPDoc.Save2(False)
oPDoc.Close(True)
Else
'MsgBox(oFile & vbCrLf & "Is not an iPart.",,"")
oPDoc.Close(True)
End If
Next
End Sub
Private Function ChooseFolder() As String
Dim ThisApplication As Inventor.Application = GetObject(,"Inventor.Application")
Dim oFolder As String = ""
Dim oPlaceHolder As String = "PlaceHolderText"
Dim oDirSepChar As Char = System.IO.Path.DirectorySeparatorChar
Dim oOpenDlg As New System.Windows.Forms.OpenFileDialog
oOpenDlg.Title = "Select A Folder."
oOpenDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
oOpenDlg.Filter = ""
oOpenDlg.Multiselect = False
oOpenDlg.RestoreDirectory = False
oOpenDlg.CheckFileExists = False
oOpenDlg.CheckPathExists = True
oOpenDlg.ValidateNames = False
oOpenDlg.FileName = oPlaceHolder
oOpenDlg.AddExtension = False
oOpenDlg.DefaultExt = ""
Dim oResult = oOpenDlg.ShowDialog
If oResult = vbOK Then
If oOpenDlg.FileName <> vbNullString Then
oFolder = oOpenDlg.FileName
Else
MsgBox("No file was selected. Exiting.", vbOKOnly + vbExclamation, "FILE NOT SELECTED")
Exit Function
End If
ElseIf oResult = vbCancel Then
MsgBox("The dialog was Canceled. Exiting.", vbOKOnly + vbInformation, "CANCELED")
Exit Function
End If
'count the number of characters from the end, until it finds the directory separator character
Dim oPos As Integer = InStr(StrReverse(oFolder), oDirSepChar)
'check if the directory separator character was at the end, if so, perfect, if not, eliminate end text
If oPos <> 1 Then
'the directory seperator character was not at the end, so...
oFolder = Strings.Left(oFolder, InStrRev(oFolder, oDirSepChar))
End If
Return oFolder
End Function
Wesley Crihfield
(Not an Autodesk Employee)
