08-09-2021
11:09 AM
- Mute
- Permalink
- Report
08-09-2021
11:09 AM
Or with a selection via a dialog:
Dim d As Inventor.FileDialog Call ThisApplication.CreateFileDialog(d) d.MultiSelectEnabled = True d.Filter = "Parts|*.ipt" d.ShowOpen d.CancelError = False If Not d.FileName = "" Then Dim a() As String = Split(d.FileName, "|") i=0 For i = 0 To UBound(a) Dim partDoc As PartDocument = ThisApplication.Documents.Open(a(i)) If partDoc.ComponentDefinition.IsiPartMember Then partDoc.ComponentDefinition.iPartMember.BreakLinkToFactory Return 'do nothing Else MessageBox.Show("This is NOT an iPart", "Title") End If partDoc.Save partDoc.Close Next End If
Arthur Knoors
Autodesk Affiliations:
