With this you can in ilogic:
Dim partDoc As PartDocument = ThisApplication.ActiveDocument
If  partDoc.ComponentDefinition.IsiPartMember Then
     partDoc.ComponentDefinition.iPartMember.BreakLinkToFactory
    Return 'do nothing
Else
MessageBox.Show("This is NOT an iPart", "Title")
End If
Arthur Knoors
Autodesk Affiliations:
