WCrihfield
in reply to: werft60
If the local code is going to be exactly the same in all your documents being produced from the template, why not make the rule an external rule, then use a small simple local rule that just runs that external rule.  This simple rule would then be the one located in your template, and the rule that would get copied to all new documents, based on that template.  This way, the main complex part of the code is in one place, easily fixable, when needed.  Or maybe I misunderstood and that is already your plan.  I use a lot of those simple 'run external rules' type of local rules, to avoid the duplication of complex code.
Wesley Crihfield
(Not an Autodesk Employee)
