floccipier
486 Views, 2 Replies
Excluding visible = false from occurances.AllReferencedOccurrences
Hi all,
I am struggling to figure out how I can remove invisible (visible = false) items from component occurances count.
best regards,
Flo
JhoelForshav
in reply to: floccipier
Hi @floccipier
If you dont want to use a for each loop and just loop through the occurrences, checking each one of them if it's visible or not and add +1 to an integer if so, you can do it like this :slightly_smiling_face: (oDoc = the document your'e checking all referenced occurrences of)
Dim oAsm As AssemblyDocument = ThisDoc.Document
MsgBox(oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc).OfType(Of ComponentOccurrence).Where(Function(x) x.Visible = True).Count)
Otherwise something like this is probably the most simple way to do it:
Dim count As Integer = 0
For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc)
	If oOcc.Visible Then count += 1
Next
MsgBox(count)
bhavik4244
@floccipier
Try this!
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
Dim oList As New List(Of Integer)
For Each oOccurrence In oAsmCompDef.Occurrences
	If oOccurrence.Visible = True Then
	oList.Add(oAsmCompDef.Occurrences.Count)
End If
x1 = oList.Count
Next
MessageBox.Show(x1, "Number of VisibleComponents")
Bhavik Suthar
