07-20-2021
10:52 AM
- Mute
- Permalink
- Report
07-20-2021
10:52 AM
Yes. That iLogic snippet is basically a shortcut tool, but it definitely has a standard counterpart. You will need to drill down through the object model to get to the related methods though. Under the AssemblyDocument, then the AssemblyComponentDefinition, then the AssemblyConstraints, is a list of similar methods for creating constraints , one of which is called 'AddMateConstraint()' (or its later version 'AddMateConstraint2().
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS)
If you want and have time, I would appreciate your Vote(s) for My IDEAS
or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
