- Mute
- Permalink
- Report
Apologies if I posted this in the wrong place this is my first post.
Basically I've made a rule that takes in some user information and then copies an existing assembly and places it in a new file location. The rule then opens this new assembly file and makes some edits. The edits are working perfectly until I try to add some mates to the assembly.
I'm currently using:
Constraints.AddMate("Door_YZ" & MateNumber, {DoorName, "Stile:1" }, YZFace, "", "YZ Plane", XOffset)
Though I'm getting an error because the rule doesn't recognize the component name (DoorName, "Stile:1"). This is because Constraints.AddMate is referenced by ThisRule which is the document where the rule is running not the one I'm trying to edit.
Is there any other way to add constraints where I can reference the active file?
