07-12-2021
05:51 AM
- Mute
- Permalink
- Report
07-12-2021
05:51 AM
Hello
I think the creation of the geometry intent fails silently. Afaik a point of a sketched symbol is not a valid input for this.
Dim GeomIntentText As GeometryIntent = oSheet.CreateGeometryIntent(ThisPoint, ThisPoint.Position)If I'm right, all of your sketched symbols are attached to endpoints of drawingcurves. If so, every sketched symbol has a (invisible) leader with an attached entity. This entity is a geometry intent (drawing curve) where your leader note can also be attached to. If the drawingcurve endpoint moves, your leader note should also do. Finally you could change the leader style from the standard arrow to a big filled dot to replace the sketched symbol or remove the arrow.
R. Krieg
RKW Solutions
www.rkw-solutions.com
