07-06-2021
02:00 AM
- Mute
- Permalink
- Report
07-06-2021
02:00 AM
Create this external rule called "Get From Vault Function"
Imports Autodesk.DataManagement.Client.Framework.Vault Imports Autodesk.Connectivity.WebServices Imports VDF = Autodesk.DataManagement.Client.Framework Imports ACW = Autodesk.Connectivity.WebServices Imports AWS = Autodesk.Connectivity.WebServices Imports VB = Connectivity.Application.VaultBase Imports Autodesk.DataManagement.Client.Framework.Vault.Currency'.Properties AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll" AddReference "Autodesk.DataManagement.Client.Framework.dll" AddReference "Connectivity.Application.VaultBase.dll" AddReference "Autodesk.Connectivity.WebServices.dll"
Dim oFilePath As String = RuleArguments("oFilePath") Dim oVaultConnection As VDF.Vault.Currency.Connections.Connection oVaultConnection = VB.ConnectionManager.Instance.Connection If oVaultConnection Is Nothing Then MessageBox.Show("Not Logged In to Vault! - Login first and repeat executing this rule.") Exit Sub End If VaultPath = oFilePath.Replace("D:\Working Folder\", "$/") VaultPath = VaultPath.Replace("\", "/") SplitPath = oFilePath.Split("\") FolderPath = SplitPath(0) & "\" For i = 1 To SplitPath.Length - 2 FolderPath = FolderPath & SplitPath(i) & "\" Next Dim VaultPaths() As String = New String() {VaultPath } Dim wsFiels() As AWS.File = oVaultConnection.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths) Dim mFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(oVaultConnection,wsFiels(0)) Dim oSettings As New VDF.Vault.Settings.AcquireFilesSettings(oVaultConnection) oSettings.LocalPath = New VDF.Currency.FolderPathAbsolute(FolderPath) oSettings.AddFileToAcquire(mFileIt, VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download) Try Dim oResults As VDF.Vault.Results.AcquireFilesResults = oVaultConnection.FileManager.AcquireFiles(oSettings) RuleArguments.Arguments.Value("Success") = True Catch RuleArguments.Arguments.Value("Success") = False End Try
then put this in your local rule:
oFilePath = "you part to get from vault Full filename.ipt" Dim oRuleArguments As Inventor.NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap() oRuleArguments.Add("oFilePath",oFilePath) iLogicVb.RunExternalRule("Get From Vault Function", oRuleArguments) 'this returns True/False depending on whether download was successful or not. Dim oFileDownloadedSuccessfully As String = oRuleArguments.Item("Success") 'MessageBox.Show(oFilePath, oFileDownloadedSuccessfully) 'use this line before checking for other files oRuleArguments.Clear
If you want to refresh from vault, i delete off my local first, and then run this rule.
regards
Mark
