- Mute
- Permalink
- Report
Bolted Connection material
What is the best way to add materials to content center files?
I used the material guide to add new materials as new family members.
When I import them from the content center the material isn't added as a suffix to the bolt but the material is correct.
When I use the bolted connection, I can't choose between the different materials.
Is there a solution for this problem?
- Mute
- Permalink
- Report
For bolted connection you need each material in a different family and not more materials in the same family!
Arthur Knoors
Autodesk Affiliations:
