07-01-2021
03:51 PM
- Mute
- Permalink
- Report
07-01-2021
03:51 PM
There was a post recently where I used Split for solid body names https://forums.autodesk.com/t5/inventor-forum/adding-prefix-to-body-name/m-p/10431354#M832600. Works very well for this situation.
The below splits the part number using the special character "-" as a reference to where to stop counting. The string is then directly linked to Project Text parameter or wherever you like.
Dim PartNo As String PartNo = iProperties.Value("Project", "Part Number") 'Creats an array of strings seperated by "-" myparams = PartNo.Split("-") replaceString1 = myparams(0)'123456 replaceString2 = myparams(1)'01 replaceString3 = myparams(2)'01 MessageBox.Show(replaceString1, "Title") MessageBox.Show(replaceString2, "Title") MessageBox.Show(replaceString3, "Title") Dim Name As String 'Place the Name into a parameter or use it in some way. 'You can use input box to select which string you want to use, or in this case just to show the array contents 'Name = InputListBox("Prompt", myparams, d0, Title := "Title", ListName := "List") 'By pass selection box and use direct link Name = replaceString1 'Create text parameter called "Project" first manually Project = Name MessageBox.Show(Name , "Title")
Here is another where the array of strings are fed into an input box and you can pick what to use .
Dim PartNo As String PartNo = iProperties.Value("Project", "Part Number") 'Creats an array of strings seperated by "-" myparams = PartNo.Split("-") replaceString1 = myparams(0)'123456 replaceString2 = myparams(1)'01 replaceString3 = myparams(2)'01 MessageBox.Show(replaceString1, "Title") MessageBox.Show(replaceString2, "Title") MessageBox.Show(replaceString3, "Title") Dim Name As String 'Place the Name into a parameter or use it in some way. 'You can use input box to select which string you want to use, or in this case just to show the array contents Name = InputListBox("Prompt", myparams, Name, Title := "Title", ListName := "List") 'Create text parameter called "Project" first manually Project = Name MessageBox.Show(Name, "Title")
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
