06-30-2021
06:52 AM
- Mute
- Permalink
- Report
06-30-2021
06:52 AM
to put this all together for iLogic, here is an example
Sub Main Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveDocument Dim oDrawingDimCollec1 As ObjectCollection oDrawingDimCollec1 = GetDrawingDimForView(oDoc.ActiveSheet, "VIEW1") For Each oDim As DrawingDimension In oDrawingDimCollec1 If Round(oDim.ModelValue * 10, 1) -Round(oDim.ModelValue * 10, 0) = 0 Then oDim.Precision = 0 Else oDim.Precision = 1 End If Next End Sub Public Function GetDrawingDimForView(oSheet As Sheet, ViewName As String) As ObjectCollection Dim oDrawDimsForView As ObjectCollection oDrawDimsForView = ThisApplication.TransientObjects.CreateObjectCollection Dim oDrawDims As DrawingDimensions oDrawDims = oSheet.DrawingDimensions Dim oDrawDimIterator As DrawingDimension For Each oDrawDimIterator In oDrawDims Select Case oDrawDimIterator.Type Case kLinearGeneralDimensionObject Dim oLinearDim As LinearGeneralDimension oLinearDim = oDrawDimIterator If oLinearDim.IntentOne.Geometry.Parent.Name = ViewName Then oDrawDimsForView.Add(oDrawDimIterator) End If Case kRadiusGeneralDimensionObject Dim oRadiusDim As RadiusGeneralDimension oRadiusDim = oDrawDimIterator If oRadiusDim.Intent.Geometry.Parent.Name = ViewName Then oDrawDimsForView.Add(oDrawDimIterator) End If Case kDiameterGeneralDimensionObject Dim oDiameterDim As DiameterGeneralDimension oDiameterDim = oDrawDimIterator If oDiameterDim.Intent.Geometry.Parent.Name = ViewName Then oDrawDimsForView.Add(oDrawDimIterator) End If Case kAngularGeneralDimensionObject Dim oAngularDim As AngularGeneralDimension oAngularDim = oDrawDimIterator If oAngularDim.IntentOne.Geometry.Parent.Name = ViewName Then oDrawDimsForView.Add(oDrawDimIterator) End If Case Else 'Case is not handled... End Select Next GetDrawingDimForView = oDrawDimsForView End Function
