ganeshholkar18
411 Views, 2 Replies
Limit iLogic rule for specific view on drawing
I have below iLogic rule to control dimension precision on Inventor drawing. It updates dimension precision in all drawing views.
Is it possible to modify this rule so that it will only update dimension precision of required drawing view ?? I have a view on drawing with name as "UNDER". I want to have precise dimensions only for this view.
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
For Each oDim As DrawingDimension In oSheet.DrawingDimensions
If Round(oDim.ModelValue * 10, 1) -Round(oDim.ModelValue * 10, 0) = 0 Then
oDim.Precision = 0
Else
oDim.Precision = 1
End If
Next
BR, Ganesh
Labels (1)
Hi, it's not as straight forward as it seems.
Here is one exemple : https://adndevblog.typepad.com/manufacturing/2012/08/how-to-determine-which-drawing-dimensions-belon...
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
to put this all together for iLogic, here is an example
Sub Main
	oDoc = ThisApplication.ActiveDocument
	Dim oDrawingDimCollec1 As ObjectCollection
	oDrawingDimCollec1 = GetDrawingDimForView(oDoc.ActiveSheet, "VIEW1")
	For Each oDim As DrawingDimension In oDrawingDimCollec1
			oDim.Precision = 0
		Else
			oDim.Precision = 1
		End If
	Next
End Sub
Public Function GetDrawingDimForView(oSheet As Sheet, ViewName As String) As ObjectCollection
	Dim oDrawDimsForView As ObjectCollection
	oDrawDimsForView = ThisApplication.TransientObjects.CreateObjectCollection
	Dim oDrawDims As DrawingDimensions
	oDrawDims = oSheet.DrawingDimensions
	Dim oDrawDimIterator As DrawingDimension
	For Each oDrawDimIterator In oDrawDims
		Select Case oDrawDimIterator.Type
			Case kLinearGeneralDimensionObject
				Dim oLinearDim As LinearGeneralDimension
				oLinearDim = oDrawDimIterator
				If oLinearDim.IntentOne.Geometry.Parent.Name = ViewName Then
					oDrawDimsForView.Add(oDrawDimIterator)
				End If
			Case kRadiusGeneralDimensionObject
				Dim oRadiusDim As RadiusGeneralDimension
				oRadiusDim = oDrawDimIterator
				If oRadiusDim.Intent.Geometry.Parent.Name = ViewName Then
				End If
			Case kDiameterGeneralDimensionObject
				Dim oDiameterDim As DiameterGeneralDimension
				oDiameterDim = oDrawDimIterator
				If oDiameterDim.Intent.Geometry.Parent.Name = ViewName Then
				End If
			Case kAngularGeneralDimensionObject
				Dim oAngularDim As AngularGeneralDimension
				oAngularDim = oDrawDimIterator
				If oAngularDim.IntentOne.Geometry.Parent.Name = ViewName Then
				End If
			Case Else
				'Case is not handled...
		End Select
	Next
	GetDrawingDimForView = oDrawDimsForView
End Function
