06-26-2021
05:27 AM
- Mute
- Permalink
- Report
06-26-2021
05:27 AM
Frame Generator Demote populate metadata not working
Hi all,
I'm trying to populate the fields of the demote dialog when demoting a frame generator beam.
Somehow the fields just go back to the defaults when the popup comes. Does anyone know if I am doing something wrong or if maybe frame generator just overrides the fields?
When just clicking OK the displayname is edited correctly.
Code used:
var savingFolder = new SavingFolder(assembly.FullFileName, projectFolder);
var indexNumber = new IndexNumber(savingFolder.DirectoryName);
var basename = $"SA{indexNumber.Text}-A-1";
var assyname = $"{basename}.iam";
var fullfilename = $"{savingFolder.DirectoryName}/{assyname}";
var metadata = FileMetadataObjects.GetEnumerator().ToEnumerable<FileMetadata>().FirstOrDefault();
metadata.DisplayNameOverridden = true;
metadata.DisplayName = basename;
metadata.FileNameOverridden = true;
metadata.FileName = assyname;
metadata.TemplateFileName = Core.Properties.Settings.Default.TemplateFilename;
var properties = metadata.FileProperties;
metadata.FullFileName = fullfilename;
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
06-26-2021
05:35 AM
- Mute
- Permalink
- Report
06-26-2021
05:35 AM
For the regular demote command everything is working fine by the way.
06-26-2021
07:04 AM
- Mute
- Permalink
- Report
06-26-2021
07:04 AM
I found part of the problem. I was in the wrong assembly context, I should have been using ActiveEditDocument in this case.
However, the template is still not working for the Frame Generator demote command.
