blandb
299 Views, 3 Replies
Extract Frame generator assembly/weldment title field to the parts custom field
I have a frame generated frame that is pulled into an upper level assembly where things are then attached to it. I need to grab the upper level assembly title, or just the frame generated assembly title, and then loop through and apply that to the placed members custom iproperty called "Section" I am blanking on how to accomplish this.
Due to our syntax, it will always use the right (4) characters of the title field. So I was planning on using the right function once I got the property, but I am stuck. Any guidance will be appreciated!
Autodesk Certified Professional
Curtis_Waguespack
in reply to: blandb
Hi @blandb
Here's a link that has an example that should get you pointed in the right direction on accessing the properties of the frame members:
https://forums.autodesk.com/t5/inventor-customization/ilogic-rule-for-changing-frame-member-part-num...
I hope this helps.
Curtis
blandb
in reply to: Curtis_Waguespack
I'm not certain, but doesn't that code use the frame members to develop a part number? I am trying to just pull the title from the assembly of the frame weldment (where the members are inserted) and then place that title into each members custom iproperty.
blandb
in reply to: blandb
I believe I got something that works!
Dim asmDoc As AssemblyDocument = ThisDoc.Document
Dim childDoc As Document
For Each childDoc In asmDoc.AllReferencedDocuments
	Try
		Dim filename = IO.Path.GetFileName(childDoc.FullFileName)
		iProperties.Value(filename, "Custom", "RAIL SECTION") = right(iProperties.Value(asmDoc, "Summary", "Title"),4)
	Catch
	End Try
Next
