- Mute
- Permalink
- Report
I could some assistance with the following code. The program updates all of the views on all sheets properly.
However, I would like the option to process the current sheet only.
Here is my current code.
Dim oDoc As DrawingDocument: oDoc = ThisDoc.Document oModel = ThisDoc.ModelDocument Dim oSheets As Sheets Dim oSheet As Sheet Dim oViews As DrawingViews Dim oView As DrawingView oSheets = oDoc.Sheets If question1=vbNo Then For Each oSheet In oSheets oViews = oSheet.DrawingViews For Each oView In oViews 'make view label visible If oView.ViewType = 10501 Then oView.ShowLabel = True oView.Label.FormattedText = String1 & String2 & "<Br/>" & String4 &"<Br/>" & String3 End If Next Next Else oViews = oSheet.DrawingViews For Each oView In oViews If oView.ViewType = 10501 Then oView.ShowLabel = True oView.Label.FormattedText = String1 & String2 & "<Br/>" & String4 &"<Br/>" & String3 End If Next End If
- Mute
- Permalink
- Report
I don't see where your question1 is getting it's information from but......below I commented out the lines that you don't need just to show what I changed.
If you only want to work with the current sheet (or active sheet) then you don't need to loop through the Sheets collection. Therefore, I commented out the For / Each loop.
'Dim oSheets As Sheets
Dim oSheet As Sheet
'oSheets = oDoc.Sheets
oSheet = oDoc.ActiveSheet
' For Each oSheet In oSheets
End If
Next
' Next
Else
End If
Next
End If
Randy Mabery
Applications Expert
IMAGINiT Technologies
- Mute
- Permalink
- Report
Here's something you can try:
Sub Main
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.Sheets
If MsgBox("All Sheets [Yes] Or ActiveSheet [No]?", vbYesNo + vbQuestion,"") = vbYes Then
UpdateLabels(oViews)
Next
Else
End If
End Sub
Sub UpdateLabels(oVws As DrawingViews)
For Each oView As DrawingView In oVws
End If
Next
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS)
If you want and have time, I would appreciate your Vote(s) for My IDEAS
or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
- Mute
- Permalink
- Report
Hi Randy,
My apologies, I left the code for the question out of my post. I removed the comments and the code works perfectly.
Thank you for the quick response.
- Mute
- Permalink
- Report
Thank you as well for posting so quickly. I like your style but for whatever reason, the code errors with the following message.
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.Sheet'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{206B59AE-22A6-11D4-B7A8-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Here is the code I am using.
Sub Main sFont = "Arial" sFSize1 = 0.3 'font size in cm sFSize2 = 0.3175 'font size in cm String1 = "<StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "' Underline='False'> PN: </StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "' Underline='False'><Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='43'>PART NUMBER</Property></StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'> - </StyleOverride>" String3 = "<StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'>SCALE: </StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'><DrawingViewScale/></StyleOverride>" String2 = "<StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "' Underline='False'><Property Document='model' PropertySet='Design Tracking Properties' Property='Authority' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='43'>AUTHORITY</Property></StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'> REQ'D </StyleOverride>" String4 = "<StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'><Property Document='model' PropertySet='Design Tracking Properties' Property='Material' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='20'>MATERIAL</Property></StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'> - </StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'><Property Document='model' PropertySet='User Defined Properties' Property='G_H' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='7'>G_H</Property></StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'> THK</StyleOverride>" Dim oDoc As DrawingDocument: oDoc = ThisDoc.Document oModel = ThisDoc.ModelDocument Dim oSheets As Sheets Dim oSheet As Sheet=oDoc.Sheets Dim oViews As DrawingViews Dim oView As DrawingView If MsgBox("All Sheets [Yes] Or ActiveSheet [No]?", vbYesNo + vbQuestion,"") = vbYes Then For Each oSheet In oSheets oViews = oSheet.DrawingViews UpdateLabels(oViews) Next Else oSheet = oDoc.ActiveSheet oViews = oSheet.DrawingViews UpdateLabels(oViews) End If End Sub Sub UpdateLabels(oVws As DrawingViews) For Each oView In oVws If oView.ViewType = 10501 Then oView.ShowLabel = True oView.Label.FormattedText = String1 & String2 & "<Br/>" & String4 &"<Br/>" & String3 End If Next End Sub
- Mute
- Permalink
- Report
You're right. I see it very clearly now this morning. It's right near the top where we are creating the variables. We need to change this:
to this:
Dim oSheets As Sheets = oDoc.Sheets
Dim oSheet As Sheet
Apparently I accidentally put that Value behind the wrong variable, so it was thinking we were trying to set a Sheet type variable to a Sheets type value, which caused the error. Hopefully that fixes the error and there aren't any others. Sorry about that. ![]()
Wesley Crihfield
