342 Views, 2 Replies
06-16-2021
01:54 AM
- Mute
- Permalink
- Report
06-16-2021
01:54 AM
Hello, still coming to grips with VBA, but managed to use the same code below to insert various title blocks through a userform. I have separated the code now to just generate on the click of a button to test out inserting a drawing border. I don't seem to be able to correct the errors in the code that are giving me a 'wrong number of arguments or invalid property assignment' while highlighting the oSheet.AddBorder at the end of the code. If anyone has any ideas how to fix I would highly appreciate this.
Sub GenerateButton_Click()
'Get the active document.
Dim oDrawDoc As Document
Set oDrawDoc = ThisApplication.ActiveDocument
'Get the PropertySets object.
Dim oPropSets As PropertySets
Set oPropSets = oDrawDoc.PropertySets
' Obtain a reference to the desired border defintion.
Dim oBorderDef As BorderDefinition
Set oBorderDef = oDrawDoc.BorderDefinitions.Item("Default Border")
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
' Check to see if the sheet already has a border and delete it if it does.
If Not oSheet.Border Is Nothing Then
oSheet.Border.Delete
End If
Dim sPromptStrings(1 To 2) As String
sPromptStrings(1) = "String 1"
sPromptStrings(2) = "String 2"
' Add an instance of the border definition to the sheet.
Dim oBorder As Border
Set oBorder = oSheet.AddBorder(oBorderDef, , sPromptStrings)
Unload Me
End Sub
