602 Views, 2 Replies
setting a VBA sketch profiles problem
I try to set this sketch as profiles but there has an error. The code as follow.
I appreciate any help!
Public Sub   OOOO()
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
Dim oSketch As PlanarSketch
Set oSketch = oPartDoc.ComponentDefinition.Sketches.Add(oPartDoc.ComponentDefinition.workPlanes.Item(2))
Dim oTG As TransientGeometry
Set oTG = oApp.TransientGeometry
Dim oSkPnts As SketchPoints
Set oSkPnts = oSketch.SketchPoints
Call oSkPnts.Add(oTG.CreatePoint2d(0, 0), False) 'oSkPnts(1) 1
Call oSkPnts.Add(oTG.CreatePoint2d(0, 1.5 * 2.54), False) 'oSkPnts(2)2
Call oSkPnts.Add(oTG.CreatePoint2d(-10 * 2.54, 1.5 * 2.54), False) 'oSkPnts(7)3
Call oSkPnts.Add(oTG.CreatePoint2d(-10 * 2.54, 0), False) 'oSkPnts(8)4
Call oSkPnts.Add(oTG.CreatePoint2d(-0.10608028 * 2.54, 1.5 * 2.54), False) 'oSkPnts(11) right high 5
Call oSkPnts.Add(oTG.CreatePoint2d(-0.1841075 * 2.54, 1.43765652 * 2.54), False) 'oSkPnts(12) right high 6
Call oSkPnts.Add(oTG.CreatePoint2d(-0.10608028 * 2.54, 1.42 * 2.54), False) 'oSkPnts(13) center of right high 7
Call oSkPnts.Add(oTG.CreatePoint2d(-0.42916783 * 2.54, 0.35469256 * 2.54), False) 'oSkPnts(14) right low 8
Call oSkPnts.Add(oTG.CreatePoint2d(-0.66032347 * 2.54, 0.17 * 2.54), False) 'oSkPnts(15) right low 9
Call oSkPnts.Add(oTG.CreatePoint2d(-0.66032347 * 2.54, 0.407 * 2.54), False) 'oSkPnts(16) center of right low 10
Call oSkPnts.Add(oTG.CreatePoint2d(-9.89391972 * 2.54, 1.5 * 2.54), False) 'oSkPnts(17) left high 11
Call oSkPnts.Add(oTG.CreatePoint2d(-9.8158925 * 2.54, 1.43765652 * 2.54), False) 'oSkPnts(18) left high 12
Call oSkPnts.Add(oTG.CreatePoint2d(-9.89391972 * 2.54, 1.42 * 2.54), False) 'oSkPnts(19) center of left high 13
Call oSkPnts.Add(oTG.CreatePoint2d(-9.57083217 * 2.54, 0.35469256 * 2.54), False) 'oSkPnts(20) left high 14
Call oSkPnts.Add(oTG.CreatePoint2d(-9.33967653 * 2.54, 0.17 * 2.54), False) 'oSkPnts(21) left high 15
Call oSkPnts.Add(oTG.CreatePoint2d(-9.33967653 * 2.54, 0.407 * 2.54), False) 'oSkPnts(22) center of left high 16
Dim oLines As SketchLines
Set oLines = oSketch.SketchLines
Dim oLine(1 To 30) As SketchLine
Set oLine(1) = oLines.AddByTwoPoints(oSkPnts(1), oSkPnts(2)) 'Body
Set oLine(2) = oLines.AddByTwoPoints(oSkPnts(2), oSkPnts(5)) 'Body
Set oLine(3) = oLines.AddByTwoPoints(oSkPnts(6), oSkPnts(8)) 'Body
Set oLine(4) = oLines.AddByTwoPoints(oSkPnts(9), oSkPnts(15)) 'Body
Set oLine(5) = oLines.AddByTwoPoints(oSkPnts(14), oSkPnts(12)) 'Body
Set oLine(6) = oLines.AddByTwoPoints(oSkPnts(11), oSkPnts(3)) 'Body
Set oLine(7) = oLines.AddByTwoPoints(oSkPnts(3), oSkPnts(4)) 'Body
Set oLine(8) = oLines.AddByTwoPoints(oSkPnts(4), oSkPnts(1)) 'Body
Dim oArcs As SketchArcs
Set oArcs = oSketch.SketchArcs
Dim oArc(1 To 4)As SketchArc
Set oArc(1) = oArcs.AddByCenterStartEndPoint(oSkPnts(7), oSkPnts(5), oSkPnts(6))
Set oArc(2) = oArcs.AddByCenterStartEndPoint(oSkPnts(10), oSkPnts(9), oSkPnts(8))
Set oArc(3) = oArcs.AddByCenterStartEndPoint(oSkPnts(16), oSkPnts(14), oSkPnts(15))
Set oArc(4) = oArcs.AddByCenterStartEndPoint(oSkPnts(13), oSkPnts(12), oSkPnts(11))
Dim oProfile(1 To 4)As Profile
Set oProfile(1) = oSketch.Profiles.AddForSolid
'Extride for main body
Dim oExtrudeDef As ExtrudeDefinition
Set oExtrudeDef = oPartDoc.ComponentDefinition.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile(1), kJoinOperation)
Call oExtrudeDef.SetDistanceExtent(185.574037 * 2.54, kPositiveExtentDirection)
Dim oExtrude As ExtrudeFeature
Set oExtrude = oPartDoc.ComponentDefinition.Features.ExtrudeFeatures.Add(oExtrudeDef)
End Sub
Tags (1)
Labels (1)
