- Mute
- Permalink
- Report
I try to set this sketch as profiles but there has an error. The code as follow.
I appreciate any help!
Public Sub OOOO()
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
Dim oSketch As PlanarSketch
Set oSketch = oPartDoc.ComponentDefinition.Sketches.Add(oPartDoc.ComponentDefinition.workPlanes.Item(2))
Dim oTG As TransientGeometry
Set oTG = oApp.TransientGeometry
Dim oSkPnts As SketchPoints
Set oSkPnts = oSketch.SketchPoints
Call oSkPnts.Add(oTG.CreatePoint2d(0, 0), False) 'oSkPnts(1) 1
Call oSkPnts.Add(oTG.CreatePoint2d(0, 1.5 * 2.54), False) 'oSkPnts(2)2
Call oSkPnts.Add(oTG.CreatePoint2d(-10 * 2.54, 1.5 * 2.54), False) 'oSkPnts(7)3
Call oSkPnts.Add(oTG.CreatePoint2d(-10 * 2.54, 0), False) 'oSkPnts(8)4
Call oSkPnts.Add(oTG.CreatePoint2d(-0.10608028 * 2.54, 1.5 * 2.54), False) 'oSkPnts(11) right high 5
Call oSkPnts.Add(oTG.CreatePoint2d(-0.1841075 * 2.54, 1.43765652 * 2.54), False) 'oSkPnts(12) right high 6
Call oSkPnts.Add(oTG.CreatePoint2d(-0.10608028 * 2.54, 1.42 * 2.54), False) 'oSkPnts(13) center of right high 7
Call oSkPnts.Add(oTG.CreatePoint2d(-0.42916783 * 2.54, 0.35469256 * 2.54), False) 'oSkPnts(14) right low 8
Call oSkPnts.Add(oTG.CreatePoint2d(-0.66032347 * 2.54, 0.17 * 2.54), False) 'oSkPnts(15) right low 9
Call oSkPnts.Add(oTG.CreatePoint2d(-0.66032347 * 2.54, 0.407 * 2.54), False) 'oSkPnts(16) center of right low 10
Call oSkPnts.Add(oTG.CreatePoint2d(-9.89391972 * 2.54, 1.5 * 2.54), False) 'oSkPnts(17) left high 11
Call oSkPnts.Add(oTG.CreatePoint2d(-9.8158925 * 2.54, 1.43765652 * 2.54), False) 'oSkPnts(18) left high 12
Call oSkPnts.Add(oTG.CreatePoint2d(-9.89391972 * 2.54, 1.42 * 2.54), False) 'oSkPnts(19) center of left high 13
Call oSkPnts.Add(oTG.CreatePoint2d(-9.57083217 * 2.54, 0.35469256 * 2.54), False) 'oSkPnts(20) left high 14
Call oSkPnts.Add(oTG.CreatePoint2d(-9.33967653 * 2.54, 0.17 * 2.54), False) 'oSkPnts(21) left high 15
Call oSkPnts.Add(oTG.CreatePoint2d(-9.33967653 * 2.54, 0.407 * 2.54), False) 'oSkPnts(22) center of left high 16
Dim oLines As SketchLines
Set oLines = oSketch.SketchLines
Dim oLine(1 To 30) As SketchLine
Set oLine(1) = oLines.AddByTwoPoints(oSkPnts(1), oSkPnts(2)) 'Body
Set oLine(2) = oLines.AddByTwoPoints(oSkPnts(2), oSkPnts(5)) 'Body
Set oLine(3) = oLines.AddByTwoPoints(oSkPnts(6), oSkPnts(8)) 'Body
Set oLine(4) = oLines.AddByTwoPoints(oSkPnts(9), oSkPnts(15)) 'Body
Set oLine(5) = oLines.AddByTwoPoints(oSkPnts(14), oSkPnts(12)) 'Body
Set oLine(6) = oLines.AddByTwoPoints(oSkPnts(11), oSkPnts(3)) 'Body
Set oLine(7) = oLines.AddByTwoPoints(oSkPnts(3), oSkPnts(4)) 'Body
Set oLine(8) = oLines.AddByTwoPoints(oSkPnts(4), oSkPnts(1)) 'Body
Dim oArcs As SketchArcs
Set oArcs = oSketch.SketchArcs
Dim oArc(1 To 4)As SketchArc
Set oArc(1) = oArcs.AddByCenterStartEndPoint(oSkPnts(7), oSkPnts(5), oSkPnts(6))
Set oArc(2) = oArcs.AddByCenterStartEndPoint(oSkPnts(10), oSkPnts(9), oSkPnts(8))
Set oArc(3) = oArcs.AddByCenterStartEndPoint(oSkPnts(16), oSkPnts(14), oSkPnts(15))
Set oArc(4) = oArcs.AddByCenterStartEndPoint(oSkPnts(13), oSkPnts(12), oSkPnts(11))
Dim oProfile(1 To 4)As Profile
Set oProfile(1) = oSketch.Profiles.AddForSolid
'Extride for main body
Dim oExtrudeDef As ExtrudeDefinition
Set oExtrudeDef = oPartDoc.ComponentDefinition.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile(1), kJoinOperation)
Call oExtrudeDef.SetDistanceExtent(185.574037 * 2.54, kPositiveExtentDirection)
Dim oExtrude As ExtrudeFeature
Set oExtrude = oPartDoc.ComponentDefinition.Features.ExtrudeFeatures.Add(oExtrudeDef)
End Sub
- Mute
- Permalink
- Report
So I had a look at this out of curiosity. I am not really experienced with creating sketches like this, but I like a challenge.
The error occurred as there isn't a close loop. Constraints are missing, see image.
This issue was addressed here .
Why some of the sketch profile was constrained and more wasn't is another question?
After 58 parts later
I have added these 4 lines to close the loop and complete the profile.
'Added these lines to merge sketch points Call oLine(3).StartSketchPoint.Merge(oArc(1).EndSketchPoint) Call oLine(3).EndSketchPoint.Merge(oArc(2).EndSketchPoint) Call oLine(4).EndSketchPoint.Merge(oArc(3).EndSketchPoint) Call oLine(6).StartSketchPoint.Merge(oArc(4).EndSketchPoint) Dim oProfile(1 To 4) As Profile Set oProfile(1) = oSketch.Profiles.AddForSolid
Hope that helps
Or if this helped you, please, click (like)
Regards
Alan
- Mute
- Permalink
- Report
This isn't how it's done.. You are creating lines geometry but not constraining them together.
Here is a test iLogic Rule from me where I tested this a while ago.. :
'///////////////////////////////////VARIABLES//////////////////////////////////// Dim oDoc As Document oDoc = ThisApplication.ActiveDocument Dim oPartComp As PartComponentDefinition oPartComp = oDoc.ComponentDefinition Dim oPlanarSketch As PlanarSketch Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry '////////////////////////////SET DEFAULT UNIT TO MM////////////////////////////// Dim oMillimeterUnit As UnitsTypeEnum oMillimeterUnit = UnitsTypeEnum.kMillimeterLengthUnits oDoc.UnitsOfMeasure.LengthUnits = oMillimeterUnit '//////////////////////////////CREATE USER PARAMETERS//////////////////////////// Dim oGap1 As UserParameter = oPartComp.Parameters.UserParameters.AddByExpression("Gap_1","50","mm") '///////////////////////////////CREATE SKETCH//////////////////////////////////// oPlanarSketch = oPartComp.Sketches.Add(oPartComp.WorkPlanes.Item(3)) oPlanarSketch.Name = "Sketch 1" oPlanarSketch.Edit '///////////////////////////////PROJECT ORIGIN POINT///////////////////////////// Dim oOrigin As WorkPoint oOrigin = oPartComp.WorkPoints.Item(1) Dim oOriginPoint As SketchEntity = oPlanarSketch.AddByProjectingEntity(oOrigin) '//////////////////////FINALY DRAW THE ACTUAL PART SKETCH//////////////////////// Dim oPoint1 As Point2d = oTG.CreatePoint2d(0, 0) Dim oPoint2 As Point2d = oTG.CreatePoint2d(0, 3.3) Dim oValue1 As Double = oGap1.Value + 3 + 5 Dim oPoint3 As Point2d = oTG.CreatePoint2d(oValue1,3.3) Dim oLine1 As SketchLine = oPlanarSketch.SketchLines.AddByTwoPoints(oPoint1, oPoint2) Dim oDimention1 As TwoPointDistanceDimConstraint = oPlanarSketch.DimensionConstraints.AddTwoPointDistance(oLine1.StartSketchPoint,oLine1.EndSketchPoint,DimensionOrientationEnum.kAlignedDim,oLine1.Geometry.MidPoint) oLine1.StartSketchPoint.Merge(oOriginPoint) oPlanarSketch.GeometricConstraints.AddVertical(oLine1) Dim oLine2 As SketchLine = oPlanarSketch.SketchLines.AddByTwoPoints(oPoint2, oPoint3) Dim oDimention2 As TwoPointDistanceDimConstraint = oPlanarSketch.DimensionConstraints.AddTwoPointDistance(oLine2.StartSketchPoint,oLine2.EndSketchPoint,DimensionOrientationEnum.kAlignedDim,oLine2.Geometry.MidPoint) oDimention2.Parameter.Expression = "Gap_1 + 30 + 50" oLine1.EndSketchPoint.Merge(oLine2.StartSketchPoint) oPlanarSketch.GeometricConstraints.AddPerpendicular(oLine1, oLine2) Dim oPoint4 As Point2d = oTG.CreatePoint2d(oPoint3.X,0.8) Dim oLine3 As SketchLine = oPlanarSketch.SketchLines.AddByTwoPoints(oPoint3, oPoint4) Dim oDimention3 As TwoPointDistanceDimConstraint = oPlanarSketch.DimensionConstraints.AddTwoPointDistance(oLine3.StartSketchPoint, oLine3.EndSketchPoint, DimensionOrientationEnum.kAlignedDim, oLine3.Geometry.MidPoint) oLine3.StartSketchPoint.Merge(oLine2.EndSketchPoint) oPlanarSketch.GeometricConstraints.AddPerpendicular(oLine2, oLine3) Dim oPoint5 As Point2d = oTG.CreatePoint2d(3, oPoint4.Y) Dim oLine4 As SketchLine = oPlanarSketch.SketchLines.AddByTwoPoints(oPoint4, oPoint5) oLine4.StartSketchPoint.Merge(oLine3.EndSketchPoint) oPlanarSketch.GeometricConstraints.AddPerpendicular(oLine3, oLine4) Dim oPoint6 As Point2d = oTG.CreatePoint2d(3, 0) Dim oLine5 As SketchLine = oPlanarSketch.SketchLines.AddByTwoPoints(oPoint5, oPoint6) oLine5.StartSketchPoint.Merge(oLine4.EndSketchPoint) oPlanarSketch.GeometricConstraints.AddPerpendicular(oLine4, oLine5) Dim oLine6 As SketchLine = oPlanarSketch.SketchLines.AddByTwoPoints(oPoint6, oPoint1) Dim oDimention4 As TwoPointDistanceDimConstraint = oPlanarSketch.DimensionConstraints.AddTwoPointDistance(oLine6.StartSketchPoint,oLine6.EndSketchPoint,DimensionOrientationEnum.kAlignedDim,oLine6.Geometry.MidPoint) oLine6.StartSketchPoint.Merge(oLine5.EndSketchPoint) oLine6.EndSketchPoint.Merge(oLine1.StartSketchPoint) oPlanarSketch.GeometricConstraints.AddPerpendicular(oLine5, oLine6) oPlanarSketch.ExitEdit '//////////////////////////////EXTRUDE THE SKETCH///////////////////////////// Dim oProfile As Profile oProfile = oPlanarSketch.Profiles.AddForSolid Dim oExtrude1 As ExtrudeFeature = oPartComp.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, 0.5 , kSymmetricExtentDirection, kJoinOperation) oExtrude1.Name = "Extrusion1" '/////////////////////////////////CHANGE COLOR//////////////////////////////// Dim oAppearence As Asset oAppearence = oDoc.Assets.Add(kAssetTypeAppearance, "Generic", "Appearances") Dim oColor As ColorAssetValue oColor = oAppearence.Item("generic_diffuse") oColor.Value = ThisApplication.TransientObjects.CreateColor(0,145,255) oExtrude1.Appearance = oAppearence
Hope this helps ,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
